So for some reason with the new firmware, with my setup, the SMP is no longer respecting the differnt folder.jpg files I have in each directory. For instance, I have
TV
|_Castle
| folder.jpg #1(#1 added for reference here only)
|_Season 1
| folder.jpg #2(#2 added for reference)
|_Castle.S01E01.mkv
When I view the TV series, it wants to use the folder,jpg #2 directory for EVERY occurence. So at the series list view it shows folder.jpg #2, at the season level it shows folder.jpg #2. Then, to top it off, when looking at the episode list, for episode #1, it always shows the folder.jpg #2 image, not the Castle.S01E01.jpg episode 1 image. It does show the correct Castle.S01E02.jpg image and so on for the rest of the episode, but not episode 1.
I thought when you are at the series list view, it should show folder.jpg #1 and when I the season view, it should show the folder.jpg #2 and when at the episode level it should show the individual episode jpgs.
I tried a few different skins and even the default mochi one but they all do the same thing., even after a full clear media library.
This is using the Media Library.
