Just my opinion, take it for what you thinks itās worth.
(ā¦steps up onto soapbox)
I bought this player last November after reading opinions both for and against. It was my first Media player so I had no experience with anything else therefore I am unable to comment about them.
I have since converted 1463 DVDs to the MKV format using MakeMKV. They are stored on three 3TB Western Digital MyBook Essential drives and connected to the SMP via a powered USB hub.
I have to say the learning curve was a little steep with the lack of clear documentation occasionally, but with the help of this forum I was able to get my feeble mind wrapped around what it took to get this player to work well for me.
I watch one or two movies every evening and I have had ZERO problems with playback. Any issue I faced was due to my own lack of understanding of how the players settings worked and where to find them on the device. A little patience and some forum time paid off for me.
Frustrating? Yes occasionally.
Bugs? Without a doubt.
What electronic device do you own that has no bugs what so ever? Everything has an update occasionally.
I myself have never arrived at the point that I would say the unit wasnāt good. $100 bucks? Cāmon, Thatās a tank of gas these days. My view is if they continue to do firmware releases and fix any of the bugs itās a win. Iāve owned many products that never get updated and the manufacturer could care less. If nothing gets fixed, well I can live with it seeing as for my usage requirements the SMP works really well.
I believe my luck has been with giving the player what it wants. I looked around and saw lots of posts that said the player ālikedā MKV files so that was the route I went when converting my DVD collection.
I have since talked a friend into buying the SMP and showed him how I set mine up. He did the same with his setup and has thoroughly enjoyed his playback experience.
Iām not saying someone wonāt get a defective unit now and then. Thatās life, but ask yourself what it is youāre trying to use the player for. If you want it to comply with your formats whatever they may be, you may want to be prepared for some glitches to work through.
If you want basically trouble free experience, give the unit what it wants (i.eā¦ Read the supported formats and take heed to my comments) and youāll spend more time enjoying playback and less time frustrated.
(ā¦steps down from soapbox)
Sorry for the length but I felt compelledā¦
Just my 2 cents.
