And others that are not solved
I don’t know if all are due to the firmware upgrade but it didn’t happen before:
The main page doesn’t show up know. After login in I can just see the My Cloud mirror logo and the city picture below.
I can not access using SSH. It says access denied and I’m using the password I had before firmware upgrade.
One thing that still fails is that emule doesn’t restart after rebooting the device, and the only solution is to uninstall and install again the application.
I sent the solution to support, but it seems that they have ignored.
Thank you
