So I’ve had the same problem described here Enter Network Password? - #7 by TonyPh12345 but using my xbox one. I sorted it out on my laptop using the net use * /delete as suggested. But I can’t work out how to do that on my xbox.
These are shares that I had public, removed from public, set to full access on my admin account, but now I get asked for a username and password. however even giving this username and password (including the domain) doesn’t work.
It’s not mapping no, it’s accessing via the network shares in VLC. It
accesses via device names in my workgroup. So this one is WDMyCloudMirror.
But then I get asked for domain, username and password. The one I setup
doesn’t work. I’M guessing because I accessed the device before I added a
password, as suggested in the linked post. What with the xbox running a
Microsoft os and the error message and scenario being the same
Hi, I don’t think is supported other than using the My Cloud as a media server, which is not the way that you are trying to use it. However if you think of the Xbox as a computer I would fill the user name as driveip\username maybe that way you might be able to connect.
