There is a problem with WD Black WD4001FAEX 4TB that it will be missing if the system,whatever the OS is, gets into hibernate and waits for longer than 3 minutes, then wakes up.
Have you ever meet with this problem on the 8 series Motherboard with Intel chipset?
specifications:
8 Series Motherboards with Intel@chipset, Such as GIGABYTE:GA-H87-HD3,GA-B85-HD3,ASUS:Z87-K,H87M-PLUS
systems:
windows 7 32/64bit
windows 8 32/64bit
Waiting for your reply please as soon as possible
Thanks in advance
---------------------Update Date:12/09/2013 -----------------------------
this issue only occurs when OS is installed and booted in IDE Mode,and
it will be OK in AHCI Mode.
Replication Step:
1,Get into the BIOS Settings, set “SATA Mode Section” to"IDE Mode",
2,And then,Switch to “Boot”Tab,Set “Launch CSM” to"Disable", save and exit when finished,
3,Install windows 8 or 8.1 regardless of versions after changing BIOS settings,
4,Boot from Motherboard with no USB Device,
if OS is in hibernate for 4miniute and OS can not recover due to loss of HDD
