Hello, i have a problem with my raid 5.
Problem started when i tried to put my computer to sleep. It turned off, then on again and then in bios window it shows status “Rebuild” but all drives are green. Imgur: The magic of the Internet
BUt when i look in intel’s Rapid storage app it shows problem with one of my drives. Imgur: The magic of the Internet
What i should do at this point ?
Ive already tried WD disc utility tool and tested. Raid passed the test
Hello salemas5,
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting.
http://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support
I’ve posted same post on intel’s support forums too and they helped me to fix my issue.
https://communities.intel.com/message/517653#517653
