Problem with my WD external hdd
2 day before i plugin my WD HDD and i got masage that drive needed to be formated ??? I had around 200 GB important files on it so i almost start to cry.
Then i started chkdsk command from dos and my data get back
But case is that i now have some yelow marks in my SMART report  and  if i test it in WD Smart ware, quick drive test is FAILED, complete drive FAILED
This external HDD is old FEW months and its under garanty and i wish to replace it cos i dont want to see any errors on my backup storage. Plz, take a look at pic and tell me what to do
Thx for any info
i will try to fix my issues as  Mabkay wrote on this site.
If i dont succseed with his methods, can i return my HDD ?
Hi there, If the drive is under warranty, you can request a replacement of the drive .
i manage to fix my problem…it was some kind of sw error
my reseler told me if problem persist we will change HDD
I buy one more WD but iternal HDD with 1TB so im doing backup often as possible.
Sry about pic, i didnt know that im not able to show that serial number !
Bye Bye
Happy to read that, At your service anytime.
