After upgrade v. 2.03.24 to v. 2.08.13 problem is absent with mts (m2ts)-files 1920x1080 50p.
After upgrade v. 2.08.13 to v. 3.03.13 problem is show up, and then to v. 3.03.16 problem stay, too.
When play mts-files 1920x1080 50p (specification AVCHD 2.0):
If movie on the run (movement, action) - picture jitter (strob);
After 5-10 s sound go on the run forward from video.
I not to know what to do.
Rollback to v. 2.08.13 - problem is absent.
Mediainfo mts-file 1920x1080 50p:
General
Complete name : H:\MTS\20110924145333.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 236 MiB
Duration : 1mn 14s
Overall bit rate mode : Variable
Overall bit rate : 26.7 Mbps
Maximum Overall bit rate : 28.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=12
Codec ID : 27
Duration : 1mn 14s
Bit rate mode : Variable
Bit rate : 25.1 Mbps
Maximum bit rate : 26.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.243
Stream size : 223 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 1mn 14s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 3.97 MiB (2%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 1mn 13s
