I’m trying to play an m2ts file and nothing happens and all the system total blocks. Does anybody have an idea what is happening ?
Thanks a lot.
Thanks a lot.
I’ve had a few problems playing M2TS files from time to time. For some reason, the WD TV Live+ thinks the file type is unsupported. This does not happen all the time. What I normally do is start playing a DVD ISO file, stop it, and retry the M2TS. Then it works fine. It’s another minor bug that needs to be resolved in the next firmware update.
How are you generating your files? I normally use ClownBD to remux my files to a M2TS. It’s easy to use and gets the job done if you want no video compression.
Harlock
Thanks for your replay.
I’m trying to see now what happens when I make an mkv file. But this not a solution. I am very disappointed for this.
I use DVDFab for the conversion.
I’ ll try and the program you say.
Thanks a lot again.
You might also try posting the MediaInfo on a problem file for us to take a look at.
Ok thanks. I’ ll do it .
Format : BDAV
Format/Info : Blu-ray Video
File size : 17.5 GiB
Duration : 1h 57mn
Overall bit rate : 21.2 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 1h 57mn
Bit rate mode : Variable
Maximum bit rate : 30.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA
Muxing mode : Stream extension
Duration : 1h 57mn
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Text
Menu ID : 1 (0x1)
Format : PGS
Well, that bitrate is through the roof – you certainly won’t be able to play that streamed wirelessly (15mbps is about all you can expect even under the best of conditions, and that’s twice that) and it’s asking a lot to even play it wired (however, it *should* be able to play that with a local USB drive – I’ve never actually had a file with that high a bitrate to test).
That file is a prime example of why re-encoding to a better container and codec is worth doing, despite the time it takes (not one of my hundreds of blu-ray encodes are greater than 17mbps, even the very detailed ones).
Several of my M2TS files are at over the bitrate you posted since I do not re-encode to mkv. I’ve had no problems playing them locally with a 1 TB WD portable drive, other than the “not supported” issue noted previously.
Harlock
Yes, as I said local playback shouldn’t be an issue here.
Since the OP hasn’t said yet we’ll wait and see just how he’s trying to play these.
I connect the media player with an external hd matrox via a usb cable.
I made an mkv file too. It plays for some minutes correct but then it looses the smoothness of motion and plays frame by frame.
All the other mkv files I have downloaded from internet plays fine including what I have in dvd format.
Is there any case to be something wrong we the speed of hard drive?
I’m sure the other files you have don’t have this high a bit rate. Still, as the other poster noted, the Live should be able to handle this assuming it’s being fed the file properly.
It might be your drive – when was the last time you defragmented it? You could always try reformatting it and seeing it that helps.
Look at this but rate please. I am not a great user of all this stuff. The problem is WD sees all m2ts files of different weight but plays only the same end of the movie in each file.
DISC INFO:
Disc Title: Princ.Persii.Peski.vremeni.2010.Blu-ray
Disc Size: 47 983 202 855 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.4
PLAYLIST REPORT:
Length: 0:02:52 (h:m:s)
Size: 631 388 160 bytes
Total Bitrate: 29,31 Mbps
Angle 1 Length: 0:02:52 (h:m:s) / 0:02:52 (h:m:s)
Angle 1 Size: 524 838 912 bytes / 524 838 912 bytes
Angle 1 Total Bitrate: 24,36 Mbps / 24,36 Mbps
All Angles Length: 0:05:44 (h:m:s)
All Angles Size: 1 156 227 072 bytes
All Angles Bitrate: 26,84 Mbps
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 19500 kbps 1080p / 23,976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video (1) 15000 (15000) kbps 1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 4156 kbps 5.1 / 48 kHz / 4156 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio French 1509 kbps 5.1 / 48 kHz / 1509 kbps / 24-bit
Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps
Dolby Digital Audio Russian 640 kbps 5.1 / 48 kHz / 640 kbps
Dolby Digital Audio Ukrainian 640 kbps 5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics English 52,513 kbps
Presentation Graphics English 55,783 kbps
Presentation Graphics Estonian 44,752 kbps
Presentation Graphics French 42,230 kbps
Presentation Graphics French 0,003 kbps
Presentation Graphics Latvian 41,061 kbps
Presentation Graphics Lithuanian 49,146 kbps
Presentation Graphics Russian 47,537 kbps
Presentation Graphics Russian 0,003 kbps
Presentation Graphics Ukrainian 53,959 kbps
Presentation Graphics Ukrainian 0,003 kbps
FILES:
Name Time In Length Size Total Bitrate
00848.M2TS 0:00:00.000 0:02:52.338 631 388 160 29 309
00849.M2TS (1) 0:00:00.000 0:02:52.338 524 838 912 24 363
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:02:52.338 19 500 kbps 30 734 kbps 00:02:47.000 26 474 kbps 00:02:46.416 23 413 kbps 00:02:41.411 101 663 bytes 359 755 bytes 00:02:50.753
STREAM DIAGNOSTICS:
File PID Type Codec Language Seconds Bitrate Bytes Packets
00848.M2TS 4113 (0x1011) 0x1B AVC 172,172 19 519 420 072 536 2 285 393
00848.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 172,172 4 160 89 534 688 513 416
00848.M2TS 4353 (0x1101) 0x82 DTS fra (French) 172,172 1 510 32 507 884 193 884
00848.M2TS 4354 (0x1102) 0x81 AC3 rus (Russian) 172,172 641 13 788 160 80 790
00848.M2TS 4355 (0x1103) 0x81 AC3 ukr (Ukrainian) 172,172 641 13 788 160 80 790
00848.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 172,172 641 13 788 160 80 790
00848.M2TS 4608 (0x1200) 0x90 PGS eng (English) 172,172 53 1 131 252 6 433
00848.M2TS 4609 (0x1201) 0x90 PGS eng (English) 172,172 56 1 201 689 6 837
00848.M2TS 4610 (0x1202) 0x90 PGS fra (French) 172,172 42 909 726 5 222
00848.M2TS 4611 (0x1203) 0x90 PGS rus (Russian) 172,172 48 1 024 052 5 853
00848.M2TS 4612 (0x1204) 0x90 PGS ukr (Ukrainian) 172,172 54 1 162 413 6 605
00848.M2TS 4613 (0x1205) 0x90 PGS lav (Latvian) 172,172 41 884 543 5 086
00848.M2TS 4614 (0x1206) 0x90 PGS lit (Lithuanian) 172,172 49 1 058 710 6 040
00848.M2TS 4615 (0x1207) 0x90 PGS est (Estonian) 172,172 45 964 068 5 528
00848.M2TS 4616 (0x1208) 0x90 PGS fra (French) 172,172 0 70 7
00848.M2TS 4617 (0x1209) 0x90 PGS rus (Russian) 172,172 0 70 7
00848.M2TS 4618 (0x120A) 0x90 PGS ukr (Ukrainian) 172,172 0 70 7
00849.M2TS (1) 4113 (0x1011) 0x1B AVC 172,172 15 014 323 127 680 1 758 502
00849.M2TS (1) 4352 (0x1100) 0x86 DTS-HD MA eng (English) 172,172 4 160 89 534 688 513 416
00849.M2TS (1) 4353 (0x1101) 0x82 DTS fra (French) 172,172 1 510 32 507 884 193 884
00849.M2TS (1) 4354 (0x1102) 0x81 AC3 rus (Russian) 172,172 641 13 788 160 80 790
00849.M2TS (1) 4355 (0x1103) 0x81 AC3 ukr (Ukrainian) 172,172 641 13 788 160 80 790
00849.M2TS (1) 4356 (0x1104) 0x81 AC3 eng (English) 172,172 641 13 788 160 80 790
00849.M2TS (1) 4608 (0x1200) 0x90 PGS eng (English) 172,172 0 70 7
00849.M2TS (1) 4609 (0x1201) 0x90 PGS eng (English) 172,172 0 70 7
00849.M2TS (1) 4610 (0x1202) 0x90 PGS fra (French) 172,172 50 1 083 644 6 182
00849.M2TS (1) 4611 (0x1203) 0x90 PGS rus (Russian) 172,172 58 1 245 366 7 060
00849.M2TS (1) 4612 (0x1204) 0x90 PGS ukr (Ukrainian) 172,172 51 1 100 182 6 271
00849.M2TS (1) 4613 (0x1205) 0x90 PGS lav (Latvian) 172,172 0 70 7
00849.M2TS (1) 4614 (0x1206) 0x90 PGS lit (Lithuanian) 172,172 0 70 7
00849.M2TS (1) 4615 (0x1207) 0x90 PGS est (Estonian) 172,172 0 70 7
00849.M2TS (1) 4616 (0x1208) 0x90 PGS fra (French) 172,172 0 70 7
00849.M2TS (1) 4617 (0x1209) 0x90 PGS rus (Russian) 172,172 0 70 7
00849.M2TS (1) 4618 (0x120A) 0x90 PGS ukr (Ukrainian) 172,172 0 70 7
[/code]
<---- END FORUMS PASTE ---->
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Playlist: 00875.MPLS
Length: 0:02:52
Video: MPEG-4 AVC Video / 19500 kbps / 1080p / 23,976 fps / 16:9 / High Profile 4.1
Video: MPEG-4 AVC Video (1) / 15000 (15000) kbps / 1080p / 23,976 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 4156 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Audio: French / DTS Audio / 5.1 / 48 kHz / 1509 kbps / 24-bit
Audio: English / Dolby Digital Audio / 5.1 / 48 kHz / 640 kbps
Audio: Russian / Dolby Digital Audio / 5.1 / 48 kHz / 640 kbps
Audio: Ukrainian / Dolby Digital Audio / 5.1 / 48 kHz / 640 kbps
Subtitle: English / 52,513 kbps
Subtitle: English / 55,783 kbps
Subtitle: Estonian / 44,752 kbps
Subtitle: French / 42,230 kbps
Subtitle: French / 0,003 kbps
Subtitle: Latvian / 41,061 kbps
Subtitle: Lithuanian / 49,146 kbps
Subtitle: Russian / 47,537 kbps
Subtitle: Russian / 0,003 kbps
Subtitle: Ukrainian / 53,959 kbps
Subtitle: Ukrainian / 0,003 kbps
Welcome to the forums.
All you’ve shown us is the info for an entire disc rip. It doesn’t show us any information we’d need.
Normally you rip a blu-ray to a directory that has subfolders, one of which is BDMV. In THAT sub-folder there are sub-folders one of which is STREAM. In the STREAM sub folder there will be various M2TS files and most of the time the very largest one will be the one containing the entire movie (about 3% of the time you will need to do further things because the movie will be composed of more than one M2TS file but let’s leave that aside for a moment).
The Live can play the M2TS files, but you haven’t show us a structure like this. I really can’t tell anything much from your structure (which probably means it wasn’t ripped correctly).
Mike thank you for the respond. But I can’t quite understand what you need to help me. Isn’t Stream diagnostics helpful? Look. I downloaded this rip from http://rutracker.org/forum/viewtopic.php?t=3131987
As I’ve mentioned no m2ts is able to play the movie (even the biggest one). All of them show me just the credits.
Well, obviously this rip comes from an illegal source, so I doubt, that anyone in this forum will support you on this any further…
Cheers,
Zap
You get what you pay for when downloading pirate stuff.
I’m freezing this thread since it’s obviously gotten off track.
