Good evening.as i was working on my pc, windows pop-up a message which said: ‘‘Windows detected a problem with your hard drive’’ It also said that i had to do backup and to replace my hard drive immediately. I installed hd sentinel and diagnostic tool from WD so i attach images to tell me your opinions.Thanks in advance
Hi you need to find out if the drive is in warranty. If you go here and click warranty check it will tell you. http://support.wdc.com/warranty/index_end.asp?lang=en . If the drive is still under warranty then click the Product replacement RMA link and follow that through to RMA your drive. If you want to make sure it is a warranty replaceable hard drive with those errors please contact WD support from this link http://support.wdc.com/contact/index.asp?lang=en
you arer lucky to have the drive working now… if damage afects firmware in the platters you will not be able to retrieve your data without a recovery company
