i have many problems to access the ftp-server on my My Cloud Mirror Gen . 2 with FW 2.11.140. All rights are set in the WD GUI-Dashboard. If i will access the ftp, the login goes right, but after there it is impossible to see the directory content (yes it has content) and it is also impossible to write/store new files or create directories.
cmd-Screen:
ftp> mkdir test
550 Sorry, users are not allowed to create directories
ftp>
Btw., i have another My Cloud Mirror 12 TB Gen 2. with FW 2.11.133 and this works fine.
It likes be wrong permissions, but where has them to set? Both Mirrors has the same permissions in the Dashboard. Only the one with the FW 2.11.140 makes trouble.
Any ideas? Firmware Bug or User-Bug?
Thanks for help.
Regards
