Problem with Backup freeze
I have been using WD Smartware for over 1 year and was doing automatic backups probably every 2-3 weeks and everything went fine, I connected the drive, launched Smartware and backup started.
Now the first tab ‘Home’ shows the on-going ‘Caterorizeing you files’ and does not seem to be doing anything
The second tab ‘Backup’ shows ‘59,95MB of 7,68GB Copied’ and nothing moves at all !
I stopped it, closed everything, restarted laptop, started again Wmartware and I have the same happening !
Would anyone have a clue ? I have added the 2 screenshots below
Many thanks for your help,
Marc
Hello, welcome to the community.
What version of the Smartware you have? Have you tried updating it?
Thank for your answer and I do have an older version 1.4.5.2 and am so afraid to update it as I really do not want to loose my backup data.
I never updated it as it was working fine before, but maybe I should do !
Best regards,
Marc
