WINDOWS CANT STOP UR ‘GENERIC VOLUME’ DEV ICE BECAUSE IT IS IN USE.CLOSE ANY PROGAMS OR WINDOW THAT MIGHT BE USING THE DEVICE,AND THEN TRY AGAIN LATER.
i did check there nothing open window, i close all the window,i try remove safely noting seem work,so only way i remove is laptop is shut down… i get fed up with it… please help
