I updated the firmware via internet, now I have a strange issue:
when the WDTV boots, many videos don’t work, I get a message “Unable to play selected file”.
Then after 2-3 minutes, if I try to play the same file, it works.
Video preview also doesn’t work in the first 2-3 minutes after boot.
richUK
2
Try:
resetting the unit by pressing the side paperclip button. Press for about a second and then release with the unit fully booted up.
rest to factory defaults via the internal menu.
unplug from power for some minutes.
do all 3 one after the other.
Sometimes this helps particularly after a firmware up date.
Wow very fast reply, thanks.
Noob question: resetting to factory defaults will also rollback the firmware upgrade ?
richUK
4
No, the firmware stays the same but all settings change to their default factory setting.
