Power supply specs for ext hd
We moved! :weary:
Lost two power supplies for:
  1. My Book. WD5000D032-000
  2. WDBAAU0010HBK-00
Desperately looking for specs for power supplies for both drives.
Need to know voltage and amps.
Appreciate any help and many thanks in advance
Sights. :smile:
The My Book model number WD5000D032-000 uses a 12 Volts 2.0 Amps 24 Watts
The model WDBAAU0010HBK uses 12 Volts 1.5 Amps 18 Watts
The following link is for the list of WD units and the power adapters that works for them.
Thanks ERmorel, really appreciate the info and the link :grinning:
You are welcome.
Hope it helps you and others.
