Power Supply Question
I have a MyBook Essential Edition M/N: WD5000C032-002 and the power supply it came with (12V 2A) stopped working. I have another power supply made by Duracell which is 12V 1.7A. Should I use this power supply or not?
See if this helps  https://wdc.custhelp.com/app/answers/detail/a_id/1378/session/L3RpbWUvMTMyMDE3MTc3OS9zaWQvak9TMVcxSWs%3D
Joe
I was already at that page and I know it says which power supply to use. Although just because it is rated at 2Amps does that mean it will absolutely draw that amount?
