hello everyone. I am anew member. I bought a my net Wi-Fi range extender 2-3 weeks ago. at set up the power light just blinks. I have tried to reboot, as well as reboot the modem at set up also, with no luck. any ideas? thanks to all for consideration. dave
Hello ddnyman,
http://support.wdc.com/support/case.aspx?lang=en
