after a sudden power interruption our McCloud DL2100s power light flashes contiuosly for 5 minutes followed by the unit rebooting its self. This cycle of flashing and rebooting continues until the unit is powered off. Any body got any ideas how to overcome this.
Have you tried a reset?
Not yet. Would you recommend the 4 second or 40 second reset?
Try the 4 (I’d give it 5 or 6 for good measure) and if that doesn’t work go for the 40.
Thanks for your help.
Did the reset resolve the issue?
