Haven’t been able to find power consumption information for internal hard drives. Should be included in Specifications data, for active and idle disk status. If somebody has this information could they please add it to this discussion?
What is the model number of your hard drive?
Hello Hamlet,
Model number : WD50 00AAKS-65V0A
Thanks for your reply -sorry it took me a day to get back to you.
Click on the link below in order ot get the Spec sheet for this model.
If the answer is not there then I recommend you contact WD support directly.
Contact WD
Hamlet,
Yes- that document has the info I was looking for. Thanks very much!
/A
