Hello guys.
I bought my WDTV Play today, and hooked everything up as required.
I have a power light, but nothing shows on the TV screen on either HDMI or Component settings.
However, if i leave it for a few minutes, I get the WD Screensaver showing on my screen, and if i press the power off button, i see the WD Splash Screen showing for a split second.
What could be the problem? Have tried on all 3 HDMI ports and on the Component plug too. I don’t have them plugged in at the same time, i’m removing one before trying the other.
I’ve also tried the reset button a couple of times too.
There’s nothing wrong with any of the ports as my PS3 works perfectly fine on them.
The network can also see the WDTV device, but I can’t pair it as it asks for an access code which i assume I can’t get unless i can access the settings on the device
Thanks for any advice
