i have this wd sharespace 4tb from my boss and its not working. he said check for failed components so i decided to register to wd forums for more ideas before i check the motherboard for components failures.
problem:
when i plug the wd ss 4tb all lights are up.
when i tried to press the power button it does not respond either the fan wont shuts off.
when i put usb connection going to computer it is not detected.
do you know if is in the mb itself? thank you
