Hi, I can see my list of files fine, but won’t play them just says connecting for ages. All are MP4 for Apple TV format.
I’m using a Lenovo yoga tab 3. It has this fault while at home with good WiFi signal.
Also, if I go out, using other WiFi, I can see picture but it’s like watching in slow motion, picture and sound stutter, using BS player.
I’ve tried VLC, but wouldn’t work.
I am running latest version of software for players operating system, and hardrive ect. My speed actual download speed is 6mb, as I’m on a 8mb package. Not sure of my upload speed, but surely there is a player which buffers all, if u wait say ten mins.
I am only trying to play a 20 minutes clip.
Internet videos work fine from this device in all locations using WiFi.
Please help me.
Many thanks.
Kevin chamberlin.
http://support.wdc.com/support/case.aspx?lang=en
If these movies are downloaded FROM Apple for playing on Apple TV they will not play on anything but the Apple TV because they are copy-protected. They sure won’t play on any other device.
