I’m wanting to know if the “WD My Passport Wireless Pro Hard Case (Wdbnar0000nbk-wasn)” fits the Passport Wireless Pro 4TB edition? I can’t find anywhere online whether it does or not.
You should contact the Seller from which you are going to purchase to get the conformation about this. However, it should fit as it is for same device but take confirmation before the purchase, would prevent from loss.
