I have following disks:
2 x My Passport Essential SE (USB 3.0) 1 TB
1 x My Passport Essential SE (USB 2.0) 1 TB
I have the newest framework on every drive (they have diffrent versions but its not possible to update).
I use Smartware 3.1.0.15 and windows 7 x64.
On every disk I use WD locker.
I would like to use 3 disks in same time (two disks in USB 3.0 port).
After I connect two disks that support 3.0, and unlock both drives just one partition is showing.
When I do the same with disk 2.0 and 3.0 its working without any problem.
My laptop support two ports usb 3.0. I thought its the power problem so I bought special "Super Speed USB (usb 3.0) Express card with additional power 5V 2A.
With this express card (I connect one disk 3.0 to laptop, and another 3.0 to express card - its also not working).
When I connect 3 disks in same time I can unlock all of them but just two partitions are showing (should be 3) - one disk usb 2.0 and 3.0
