I have a 750 GB Portable Passport that I can not see the back-ups on its drive in 3 of 5 pc’s I have connected the drive to.
One of the pc’s that I can see the backup data is a Win 7 Laptop, the other is a Win10 desktop. The Win 10 desktop shows a CD/WD dual drive letter, K, but then it also shows a drive letter J which when I click shows me all of the backup files.
On two other Win 10 desktops and one Win 10 laptoptop I can only see a combo drive letter for the CD Drive/WD Passport. On these pc’s I can not see the backup files.
This has me confused as a heat exhausted road lizard. I have two other 1 TB PassPorts which I have no problem with at all as they both can see all of my backups on all five of the pc’s that I have tested, Win 7 and Win 10 pc’s.
This one 750 PassPort showing a combo CD/WD drive letter and not showing any of my backups has me as confused as a run-on road lizard. Is the 750 GB PassPort bad? All three of my PassPorts have different cable connections, so I can’t swap them to check for a bad cable. The 750 PassPort turns on, the light blinks, I can feel the slight on vibration. What is the deal with this 750 GB PassPort?
I thought at first that it was a Windows 10 issue, but not now. Anyone having this problem and have an answer please?
