Greetings,
I updated my 1st Gen WD MyCloud NAS from a 4Tb to an 8Tb drive awhile back and didn’t notice this issue until recently. I’m getting the “Partition 1 does not start on physical sector boundary.” error from fdisk. Does anyone know if there is a way to align the partition correctly or will I need to start over from scratch and rebuild the system again? The system has been a bit unstable (sometimes it doesn’t boot up correctly and takes a couple tries to get it running) it was not unstable before I replaced the drive.
Thanks for any info!
Here’s the output I’m getting from the “fdisk -l” command:
MyCloud:~# fdisk -l
WARNING: GPT (GUID Partition Table) detected on ‘/dev/sda’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/sda: 8001.6 GB, 8001563222016 bytes
255 heads, 63 sectors/track, 972801 cylinders, total 15628053168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sda1 1 4294967295 2147483647+ ee GPT
Disk /dev/md1: 2047 MB, 2047803392 bytes
2 heads, 4 sectors/track, 499952 cylinders, total 3999616 sectors
Disk /dev/md1 doesn’t contain a valid partition table
