OS X / Airport / WEP / Network connection issues!
I have installed the latest firmware update.
I can connect to the network when wireless security (password)  is turned off.
From what I’ve read, WD TV Live needs/likes WPA2 and the OS X Aiport only uses WEP.
What are my options beside buying a router?
I’d rather return the device and buy an Apple TV - but I love our old WD TV.
HELP!
Does it work if you set your SSID to BROADCAST mode?
