Yesterday i tried to play .mvk file with AAC 2ch sound and there was no sound. The player is connected to a Tv via HDMI, the audio output is set to auto. As far as i know, the problem with AAC files is only when they are multichannel, but here is 2 channel only. I’m using the latest firmware
Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : Main Codec ID : A_AAC Duration : 25mn 26s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Default : Yes Forced : No
