I have wdtv live hub and I have misplaced it’s remote. When I connect it to my Android TV, it moves to the main screen but doesn’t work with any other remote. Is there any way to get this working ? When I connected a USB drive the pop-up was also displayed but I’m just not able to select anything or browse files.
I have connected it to etehernet cable but it doesn’t show any network setting either.
The hub responded when I connected it to my laptop. (Win 8) I was able to access the wdtv using wdtv Discovery tool.
Can I know why it isn’t responding on the TV and what can be a possible solution ? Do I need to buy a replacement remote to get this working? Lastly does the hub always require internet connection to play files ?
Thanks.
