Have wd5000h1u-00 that won’t power-on. wills the poser cord from my wdbfjk40hbk work with this drive so I can check it if is the power cord?
I’m not sure which drive the wd5000h1u-00 is, but as long as the barrel connector fits and the voltage outputs are the same, you should be fine.
