I am using NFS to export my mycloud disk to my raspberry PI running Xbian.
Everything works as expected, no problem so far.
But if i connect an USB disk formated in ntfs, i have a problem with NFS.
No problems on mycloud everything works, but trying to acess the volume via NFS will result in a freeze on the raspberry.
Reboot will not solve the problem.
The only way to fix it, is to access the mycloud via ssh and restarting the nfs service with:
service nfs-kernel-server restart
once done that everything works as expected again.
it would be nice if in the next firmware everytime a new disk is mounted or unmounted this comand could be run automaticly.
