Im running windows 8 pro 64 bit x79a 3820 Intel quadcore i7 3.6 GHz 16gb ddr3 with the WDTV Livehub over a 150Mb wireless n network. At first I successfully synced my box with my PC and it started syncing at about 2 megs/sec. However whenever I start doing things online or anything that seems to use bandwidth the sync stops. That’s not the problem. THE PROBLEM IS that it does not restart the sync. ive reset both my PC and my live hub. ive reset the sync folder settings on the hub side and still no joy. The only thing that has gotten it to sync again is if I delete the sync folder and all the data, which is stupid because I end up backtracking and losing about 7 gigs of already transferred data.
Additionally, id like to simply stream my videos from my comp of the network onto my livehub so I don’t have to wait 2 hours to have my file on my hub. The file is 1080p at about 11megs/sec…Choppy as **bleep**. As ive already said, it is a completely wireless n network capable of 150 Mb data transfer. Whats the deal with the bandwidth here? Ive already changed the channel in my router- no joy. so to summarize, (1) network sync interruption-wont restart (2) when I try to stream 1080p from PC to hub frames are choppy/laggy as **bleep**. Any help is greatly appreciated.
Ian
