Very simple network - Windows Vista PC, WDTVLiveHub connected through a Netgear DSL modem/router.
When I try to access network shares and select Windows Shares I get a spinning arrow for a very long time. I used to see my PC name pop up after several minutes. Now I don’t even get that.
WDTVLiveHub address is 192.168.1.215
My computer name is DYKESPC
A picture of a Wireshark capture follows. Can anyone tell me why there might not be any responses to the NBNS name queries?
Thanks for replying Tony. I used that post several days ago to begin my troubleshooting. As you can see from the following, my WDTVLiveHub is the Master Browser on my network.
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
Not enough storage is available to process this command.
C:\Users\OWner>net view
Server Name Remark
\DYKESPC Dykes PC
\WDTVLIVEHUB WDTV LIVE
The command completed successfully.
C:\Users\OWner>nbtstat -a dykespc
Local Area Connection:
Node IpAddress: [192.168.1.121] Scope Id:
NetBIOS Remote Machine Name Table
Name Type Status
DYKESPC <00> UNIQUE Registered
WORKGROUP-PC <00> GROUP Registered
DYKESPC <20> UNIQUE Registered
WORKGROUP-PC <1E> GROUP Registered
MAC Address = 00-1A-92-24-9F-20
C:\Users\OWner>nbtstat -a wdtvlivehub
Name Type Status
WDTVLIVEHUB <00> UNIQUE Registered
WDTVLIVEHUB <03> UNIQUE Registered
WDTVLIVEHUB <20> UNIQUE Registered
…__MSBROWSE__.<01> GROUP Registered
WORKGROUP-PC <1D> UNIQUE Registered
One thing that perplexes me is why your PC is sending NOTHING… No responses to any queries – no other traffic of any kind. – or was that a filtered capture?
It’s OK for it to be the master browser since it is, in fact, a server… as long as it can do the job.
Yet to be determined if it’s the browser because no one else wanted the job, or if something else is going on. :)
Last time I remember looking, the Hub was a pretty low-priority in the election criteria, so it generally WON’T be the master browser if an election ensues.
Tony that was a continuous (sequential packets) excerpt from the Wireshark capture. My PC occasionaly sources out packets but never to the WDTVLiveHub it seems. When my WDTVLiveHub joins the network it always ends up as the master browser. Following is a Wireshark excerpt which includes a broadcast my WDTVLiveHub (192.168.1.215) that seems to indicate it is assuming the Master Browser role. See packets 244 and 245. I hope you can read it. If I take my WDTVLiveHub offline. My PC becomes the Master Browser. I confirmed this with the nbtstat -a command.
