we have a strange problem since a year and I tried a lot of stuff.
Problem:
We have 2 of the WD Live II Storage systems. The same.
One of them is working, the other not.
Both have the same Firmware and absolute the same configuration.
What happened:
Ping is possible
After a while / 1 day - One of them is not reachable. Ping is okay but I have no access via Network or via Browser direct over the IP.
I changed Network cable, the ports, - Same issue.
Perhaps the log file can help Does anyone have an idea?
best, Phil
03/31 20:57:48 BackUp-Silvi daemon.info wixEvent[3496]: System Startup - System startup.
03/31 20:57:48 BackUp-Silvi daemon.warn wixEvent[3496]: System Abnormal Shutdown - System had abnormal shutdown last time.
03/31 20:57:47 BackUp-Silvi daemon.info init: Starting pid 4018, console /dev/ttyS0: ‘/sbin/getty’
03/31 20:57:46 BackUp-Silvi daemon.info init: Starting pid 4017, console /dev/null: ‘/bin/touch’
03/31 20:57:36 BackUp-Silvi daemon.info wixEvent[3496]: Network IP Address - NIC 1 use static IP address 192.168.2.133
03/31 20:57:36 BackUp-Silvi daemon.info wixEvent[3496]: Network Link - NIC 1 link is up 1000 Mbps full duplex.
03/31 20:57:30 BackUp-Silvi syslog.info syslogd started: BusyBox v1.1.1
03/31 09:23:36 BackUp-Silvi daemon.notice afpd[10717]: Disconnected session terminating
03/31 09:23:36 BackUp-Silvi daemon.err afpd[10717]: afp_alarm: reconnect timer expired, goodbye
03/31 03:26:14 BackUp-Silvi daemon.notice afpd[25361]: Disconnected session terminating
03/31 03:26:14 BackUp-Silvi daemon.notice afpd[25361]: dsi_disconnect: entering disconnected state
03/31 03:26:14 BackUp-Silvi daemon.err afpd[25361]: dsi_stream_read: len:0, unexpected EOF
03/31 02:27:52 BackUp-Silvi daemon.notice afpd[24726]: Disconnected session terminating
03/31 02:27:52 BackUp-Silvi daemon.notice afpd[24726]: dsi_disconnect: entering disconnected state
03/31 02:27:52 BackUp-Silvi daemon.err afpd[24726]: afp_alarm: child timed out, entering disconnected state
03/31 01:26:56 BackUp-Silvi daemon.notice afpd[24082]: Disconnected session terminating
03/31 01:26:56 BackUp-Silvi daemon.notice afpd[24082]: dsi_disconnect: entering disconnected state
03/31 01:26:56 BackUp-Silvi daemon.err afpd[24082]: afp_alarm: child timed out, entering disconnected state
03/31 00:26:29 BackUp-Silvi daemon.notice afpd[23364]: Disconnected session terminating
03/31 00:26:29 BackUp-Silvi daemon.notice afpd[23364]: dsi_disconnect: entering disconnected state
03/31 00:26:29 BackUp-Silvi daemon.err afpd[23364]: afp_alarm: child timed out, entering disconnected state
03/31 00:24:28 BackUp-Silvi daemon.notice afpd[23363]: Disconnected session terminating
03/31 00:24:28 BackUp-Silvi daemon.notice afpd[23363]: dsi_disconnect: entering disconnected state
03/31 00:24:28 BackUp-Silvi daemon.err afpd[23363]: dsi_stream_read: len:0, unexpected EOF
03/31 00:24:26 BackUp-Silvi daemon.notice afpd[23270]: Disconnected session terminating
03/31 00:24:26 BackUp-Silvi daemon.notice afpd[23270]: dsi_disconnect: entering disconnected state
03/31 00:24:26 BackUp-Silvi daemon.err afpd[23270]: dsi_stream_read: len:0, unexpected EOF
03/31 00:22:28 BackUp-Silvi daemon.err afpd[23270]: bad function 7A
03/30 23:39:22 BackUp-Silvi daemon.notice afpd[10717]: dsi_disconnect: entering disconnected state
03/30 23:39:22 BackUp-Silvi daemon.err afpd[10717]: dsi_stream_read: len:0, unexpected EOF
03/30 23:39:22 BackUp-Silvi daemon.err afpd[10717]: dsi_stream_read: len:-1, Connection timed out
03/30 23:39:22 BackUp-Silvi daemon.err afpd[10717]: read: Connection timed out
03/30 23:22:14 BackUp-Silvi daemon.notice afpd[10717]: afp_zzz: entering extended sleep
03/30 22:40:43 BackUp-Silvi daemon.notice afpd[21039]: afp_disconnect: primary reconnect succeeded
03/30 22:40:41 BackUp-Silvi daemon.notice afpd[3464]: Reconnect: killing new session child[21039] after transfer
03/30 22:40:41 BackUp-Silvi daemon.notice afpd[10717]: afp_dsi_transfer_session: succesfull primary reconnect
03/30 22:40:41 BackUp-Silvi daemon.notice afpd[3464]: Reconnect: transfering session to child[10717]
03/30 22:40:41 BackUp-Silvi daemon.notice afpd[21039]: afp_disconnect: trying primary reconnect
03/30 22:40:41 BackUp-Silvi daemon.notice afpd[21039]: AFP3.3 Login by guest
03/30 22:33:13 BackUp-Silvi daemon.notice afpd[10717]: afp_zzz: entering extended sleep
03/30 21:24:28 BackUp-Silvi daemon.notice afpd[10717]: afp_zzz: waking up from extended sleep
03/30 21:18:35 BackUp-Silvi daemon.notice afpd[10717]: afp_zzz: entering extended sleep
03/30 21:04:42 BackUp-Silvi daemon.notice afpd[19395]: afp_disconnect: primary reconnect succeeded
03/30 21:04:40 BackUp-Silvi daemon.notice afpd[3464]: Reconnect: killing new session child[19395] after transfer
03/30 21:04:40 BackUp-Silvi daemon.notice afpd[10717]: afp_dsi_transfer_session: succesfull primary reconnect
03/30 21:04:40 BackUp-Silvi daemon.notice afpd[3464]: Reconnect: transfering session to child[10717]
03/30 21:04:40 BackUp-Silvi daemon.notice afpd[19395]: afp_disconnect: trying primary reconnect
03/30 21:04:40 BackUp-Silvi daemon.notice afpd[19395]: AFP3.3 Login by guest
