Hi, I have got a My Book Live network storage @ 3T. Connect it to a gigabyte router and using wire connection. I can get an upload speed around 30MB/s, which is OK.
The problem is the reading speed is very slow, only around 3MB/s. I think it is abnormal. I tried to change the cable and port on the router, only got the same result.
Anyone get ideas about this problem?
Thanks!
