Hi all,
I am trying to install MySql or MariaDB on my WD MyCloud. 6 GB. Ser# WD11DB56ZYZJ.
I read your posts on the 64K page size issue and of @[ cagoune ] being able to do that.
I tried to follow his instructions but Apt-get gives me errors.
I have several SMB and NFS shares that are important on this device. So then I stopped because I did not want to brick my system.
Is it safe to continue there?
Will that install or replace libraries that will not work with this device?
Here is my list of commands:
WDMyCloud:/etc# uname
Linux
WDMyCloud:/etc# uname -a
Linux WDMyCloud 3.2.26 #1 SMP Thu Jul 9 11:14:15 PDT 2015 wd-2.4-rel armv7l GNU/Linux
WDMyCloud:/etc# cat /etc/version
04.05.00-315
WDMyCloud:/etc# cd
WDMyCloud:~# apt-get update
Get:1 HTTP: //ftp.us.debian.org jessie Release.gpg [1652 B]
Hit HTTP ://ftp.us.debian.org jessie Release
Ign HTTP ://ftp.us.debian.org jessie Release
Ign HTTP ://ftp.us.debian.org jessie/main armhf Packages/DiffIndex
Hit HTTP ://ftp.us.debian.org jessie/main Translation-en
Err HTTP ://ftp.us.debian.org jessie/main armhf Packages
Hit HTTP ://ftp.us.debian.org jessie/main armhf Packages
Fetched 1652 B in 0s (1793 B/s)
Reading package lists… Done
W: GPG error: HTTP: //ftp . us . debian .org jessie Release: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 7638D0442B90D010
WDMyCloud:~# apt-get -f install mysql-server
Building dependency tree
Reading state information… Done
You might want to run ‘apt-get -f install’ to correct these:
The following packages have unmet dependencies:
libtirpc1 : Breaks: nfs-common (< 1:1.2.8-7) but 1:1.2.6-4 is to be installed
Breaks: nfs-kernel-server (< 1:1.2.8-7) but 1:1.2.6-4 is to be installed
mysql-server : Depends: mysql-server-5.5 but it is not going to be installed
E: Unmet dependencies. Try ‘apt-get -f install’ with no packages (or specify a solution).
Correcting dependencies… Done
The following package was automatically installed and is no longer required:
libgssglue1
Use ‘apt-get autoremove’ to remove it.
The following extra packages will be installed:
nfs-common nfs-kernel-server
Suggested packages:
open-iscsi watchdog
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 268 not upgraded.
6 not fully installed or removed.
Need to get 0 B/291 kB of archives.
After this operation, 106 kB disk space will be freed.
Do you want to continue [Y/n]? Y
WARNING: The following packages cannot be authenticated!
nfs-kernel-server nfs-common
Install these packages without verification [y/N]? N
E: Some packages could not be authenticated
WDMyCloud:~#
Any help greatly apprciated.
Thm22
