I purchased a wd mynet1300 router. I couldnt get the cd to install, so i tried the address bar. It didnt work either. I called the wd tech line and they werent much help. Im suprised they didnt try to walk me through manual ip configuration. So, I took the first one back. I purchased a 2nd one. However, it did the same thing. Says it cant find the network. I know my charter cable internet connection is fine because i get connected at over 50mpbs. Anyone have any ideas? Why didnt the WD Tech help try to reconfigure my IP? Is there big problems with this unit anyone know?
I followed the directions and typed in 192.168.1.1. Unfortunately, I didnt get the WD setup Wizard. What I got was a message that it couldn’t find my internet connection. The blue light on the front panel just keep blinking blue. I sure would like to get this thing going. Am I the first one with this problem?
I have an internet connection. But, soon as i connect the ac1300 up the connection is lost.
