This happens to me erratically, maybe twice today, not again for a week. Very annoying.
I’ve read the various posts, don’t know if I should upgrade the firmware or not. Suggestions?
In this case it’s recommended to try the new firmware
are you checking a drop on the connection or weak signal?
I don’t know the answer. I didn’t have the problem before this router. I will try the new firmware and see what happens.
