MyBook 12TB: How to read SMART-status
My new MyBook 12TB makes two types of strange noises:
  1. Sometimes a series of quite fast clicks (for roughly 15 seconds, several clicks per second)
  2. Lounder noises like the typical “sound of death”
    Now I would like to check for the disks status. Is there a way to check the disk status via SMART? I have both Linux and Windows available.
CrystalDiskInfo or GSmartControl.
Here, I suggest you to check the below link that will take you through the most effective methods to keep a thorough check on the health of your hard disk and also helps you stay more productive by scheduling the disk checking and optimization tasks: https://www.stellarinfo.com/blog/how-to-check-hard-disk-health/
Hope it will help!
