my wd is locked and erasing is not possible as toomany bad sectors are there what is solution?
Hi dkatpar,
If you have the encryption using the WD Security and drive got locked then in that case you can refer the link provided below to unlock your drive but in this process you will loose all data which is there on the drive.
https://support.wdc.com/knowledgebase/answer.aspx?ID=10408#winWDSecurity
