What’s new!
Added support for 1 & 4TB HDD models
Added alert warning message when device detects SD card/USB storage with corrupted file system is used
Adjusted battery charging profile and alert message
Changed device to load plexmediaserver.sh script from new package instead of default firmware package
Disabled power button in USB direct attach storage mode to prevent unsafe USB removal
Improved WD media crawler metadata extraction performance
Resolved "Device does not have enough space for upgrade (370002)" issue when device is formatted with FAT32
Resolved "Media Server database internal server error. (31002)" issue when copying files over SMB
Resolved "Media Server database internal server error. (31002)" issue when USB import is set to Move with USB storage that is read-only
Resolved all LED flashing issue when backing up files/folder with special character from SD card
Resolved all LED flashing issue when device is returning from suspend mode
Resolved all LED flashing issue when performing USB import with device not having enough disk space
Resolved all LED flashing issue when SD card is plug and unplug repeatedly
Resolved device reboot issue when manually updating device with invalid firmware
Resolved file access permission issue with My Cloud mobile app
Resolved incorrect power LED display when device is unplugged from USB direct attach storage mode
Resolved incorrect Wi-Fi LED behavior when device is in manual Wi-Fi uplink reconnection mode
Resolved incorrect Wi-Fi LED behavior when device is in standby mode
Resolved issue of Copy button in web UI is slow to start
Resolved issue of device unable to be re-formatted by some Macbook Pro
Resolved issue of device unable to charge certain iPad 3 in power bank mode
Resolved issue of firmware uploading status missing during manual firmware update
Resolved issue of hot plugging USB or SD card may cause web UI or My Cloud mobile app to stale temporarily
Resolved issue of missing warning message when user is attempting to import content from SD/USB storage that is larger than the space available
Resolved issue of not supporting long Traditional Chinese character as Wi-Fi SSID
Resolved issue of pressing the Wi-Fi/battery button does not reinitiate the device's wireless network broadcasting
Resolved issue of SD card auto import failed to start when device is in standby mode
Resolved issue of SD/USB import progress bar slow to respond in web UI
Resolved issue of SD/USB storage with multiple partition not getting imported completely
Resolved issue of thumbnail not auto generating for the My Cloud mobile app
Resolved issue of unable to delete file/folder when Twonky DLNA server is processing the same file/folder
Resolved issue of USB import fail to start when SD card is also inserted
Resolved issue of USB import file path different than SD card import
Resolved issue of web UI displaying incorrect firmware update time
Resolved issue of Wi-Fi Auto Reconnect option missing from web UI when device is set to client mode
Resolved issue of Wi-Fi Auto Reconnection set to run when device did not join any router during onboarding
Resolved issue of Wi-Fi slow to rebroadcast SSID when device is set to battery life mode and resuming from standby
Resolved issue of Wi-Fi SSID failed to broadcast when device is set to battery life mode and resuming from standby
Resolved issue with content has incorrect timestamp from subsequent SD card import
Resolved issue with device failing to resume from suspend mode
Resolved issue with device LED takes too long to start for SD or USB import process
Resolved issue with device unable to backup iPhone running iOS10
Resolved issue with GoPro HERO4 & HERO5 Session camera which may cause device to fail when its battery is below 20%
Resolved issue with not allowing manual firmware update when device is plugged into AC power and battery is below 50%
Resolved issue with quick scan with file system check not performing scandisk
Resolved issue with user need to setup drive lock function again after firmware upgrade
Resolved issue with web UI displaying 0 KB of 0 KB during SD card import
Resolved network access issue from Windows over the 5 GHz wireless network when device is set to Battery Life mode
Resolved Plex server reset issue
Resolved SD/USB import folder name's timestamp doesn't match when the process occurred
Resolved various web UI, message display and translation issues
Resolved web UI displaying different SD card capacity than actual
Resolved web UI eject button issue with multi-partition USB storage
Resolved web UI slow response issue
Resolved Wi-fi 2.4 GHz connection issue with Sony D5503 phone
Resolved Wi-Fi 5 GHz adaptivity issue when device is within 1 meter range
Resolved Wi-Fi connection issue when device is connecting to AP router without DHCP function
Resolved Wi-Fi connection issue when switching device to wireless network with open security
Resolved Wi-Fi connection issue with two different AP routers broadcasting same SSID on 2.4 GHz and 5 GHz
Resolved Wi-Fi instability issue with Wi-Fi Inactivity Disable set to off by default
