My Passport Ultra not showing up as a drive under MY COMPUTER - Help!
Help! My brand new Passport Ultra is no longer showing up as a drive under MY COMPUTER. When I go to Devices and printers I do see it there and all details show the device is working properly. I even see the button to eject the device, but I cannot find any option to select the drive and contents there in. How can I access my files? Many thanks, Sonia
Hello Sonia,
Welcome to the WD Community.
How is the drive showing under disk management?
Please see the link below for instructions on how to check the disk management.
http://wdc.custhelp.com/app/answers/detail/a_id/1284/session/L3RpbWUvMTQxOTY5NTM4MC9zaWQvRVo0Nm1ZYW0%3D
Thank you. Under Disk Management, the drive does not show up. What to do?
Sonia
Sorry I have an update! The drive showed up as Disk 1 with 931 GB Unallocated which doesn’t make sense since there was tons of material on the drive. Thanks, Sonia
The drive may be corrupt, not removing it properly is a frequent cause. You can try data recovery software Recuva is free.
TestDisk  http://www.cgsecurity.org/wiki/TestDisk might fix it it’s free. If you are thinking about professional recovery then do nothing. Sometimes you can access the data by booting from a Linux Live CD.
Joe
