Thanks Joe_s ( is that JOE SATRIANI___ the lord of guitars i always hail)
yeah i did downloaded the same programe before i posted the matter here … the problem is this programme is also not showing the files … when i press next after selecting teh RAW DISK… its shows nothing but all empty files… this disk still running fine on TV … (however i have installed it on a crappy office PC … i ll try to install it on my much better up to day home pc where i can see if it would work ) … is there any other free software who works same as this one … i asked WD technicians also about the software you are telling but they said that they havent used and cant say anything … they have one simple solution that format and give back or give a new one … both casis they dont care about the valuable data … THanks again for the reply
I got the full version also but still this program did not helped … is there anything else which can change the file system without data loss or if there is any other third party program which can read from a RAW drive
still the Television reading each and every file and i m watching movies / photos or listning to music from that drive
only thing is its not accessablevia a PC
the recovery tool suggested above did not helped so if there is any other tool like that
