A SOLUTION HAS BEEN FOUND AND REQUIRES NO ADDITIONAL PURCHASES!
You all can thank Ayssl3 for this fix.
1) Went to Control Panel
2) Change view by to Small icons (View by is in the top right corner)
3)Go to Power Options
4)Then Click "Change plan settings" for the power plan you are using (text is in blue)
5)Then Click "Change advanced power settings" (text is in blue)
6)Then another window will pop-up. Scroll down and look for "USB settings"
7)If you click the little plus on left of USB settings, "USB selective suspend setting" will appear
8)Press the little plus next to "USB selective suspend setting" as well and "On battery:" and "Plugged in:" will appear
9)It should say DISABLED so switch it to DISABLED for both "On battery" and "Plugged in"
10)Then press Apply and then OK (Unless you want to configure other plans as well.
11) If you want to configure other plans that you use, leave that window open and Click the down arrow next to whatever plan you are active on (it will say something like this: Power4Gear Entertainment [Active] ^). If you click the down arrow next to that other plans will drop down. Just click whichever ones you use and set them to DISABLE.
Switching it to Disabled will solve the problem.
