Hi I’m having trouble getting a connection trough when my MBLD is connected via Apple Airport Extreme. I can see the unit in finder, but can’t access. Tried connecting with RJ45-cable directly with success, but still no luck finding the bug when I’m going wireless Any suggestions will be regarded as a GOLD / Jacob
what happens when you try to connect?
you might wanna try samba to connect
Go > Connect to Server > smb://mybooklive
connect as guest
let me know if that works
