MY 500 GB WD Blue SMART SHOW Warranty as 1 at 3 places IS there any problem?
ATTRIBUTE NAME                   ID           VALUE          THRESHOLD            WROST     WARRANTY
RAW READ ERROR RATE      1           200                       51                                200                  1
Spin Up Time                             3           138                      21                                  136                  1
Re-allocated Secount Count   5           200                     140                                200                    1
Tell me is there any problem & how to decode(understand) these numbers…
WD BLUE 5000AAKX
Hi the smart data is fine although it would take to long of a post to cover it all here is a link that will explain it and tell you what each entry means. http://en.wikipedia.org/wiki/S.M.A.R.T.
Can u plz tell me in short is there a problem or not?
Kaushal235:
NO. There is no problem with regard to what you have mentioned in your first post. You need not worry about the Warranty being listed as 1. It has nothing to do with the warranty of the hard drive. You must have seen this information in WinDLG. If you see green ticks for all S.M.A.R.T. values, your drive is fine.
As Hammey has said above, read the Wiki link to understand what the S.M.A.R.T. values mean and how to interpret them.
BTW, check your private messages.
