Today I use the media player functionality in my Panasonic Viera TV to play MPEG-TS video via DLNA.
My WD TV Live Hub player cannot play these files. The WDTV Live seems to be able to play them when I convert the Mpeg audio to Dolby Digital audio. However this should not be required given the specifications of the WD TV LIve hub.
My question:
- Is this a known problem?
- Is it something that is worked on to fix in a later firmware update?
Thanks for helping
Freek Tanis
Below the file details of an example video using media info.
General
Complete name : Z:\freek\documentaire\tegenlicht\California.ts
Format : MPEG-TS
File size : 2.85 GiB
Duration : 52mn 58s
Overall bit rate : 7 705 Kbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Codec ID : 2
Duration : 52mn 58s
Bit rate mode : Variable
Bit rate : 7 066 Kbps
Nominal bit rate : 10 000 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.681
Stream size : 2.61 GiB (92%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 52mn 58s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -312ms
Stream size : 97.0 MiB (3%)
Language : Dutch
Menu
Menu ID : 1 (0x1)
Duration : 52mn 58s
List : 256 (0x100) (MPEG Video) / 257 (0x101) (MPEG Audio, Dutch)
Language : / Dutch
Service name : Service01
Service provider : FFmpeg
Service type : digital television
