MP4 from Zi8 Audio Sync Problem
Hi, this is my first post so please go easy.
I am having problems playing files from my Kodak Zi8 on the WDTV Live. The file plays ok, but the audio falls out of sync. This is the media file…
Format                           : MPEG-4
Format profile                   : QuickTime
Codec ID                         : qt
File size                        : 1.22 GiB
Duration                         : 24mn 49s
Overall bit rate                 : 7 020 Kbps
Movie name/More                  : KODAK Zi8 Pocket Video Camera
Encoded date                     : UTC 2010-03-05 13:26:16
Tagged date                      : UTC 2010-03-05 13:29:09
Writing library                  : Apple QuickTime 7.6.5
com.apple.quicktime.player.movie : (Binary)
Origin                           : Digital Camera
AMBA                             :
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : Main@L4.2
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Format settings, GOP             : M=3, N=15
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 24mn 49s
Bit rate mode                    : Variable
Bit rate                         : 6 887 Kbps
Maximum bit rate                 : 12.8 Mbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Display aspect ratio             : 16:9
Frame rate mode                  : Variable
Frame rate                       : 36.690 fps
Original frame rate              : 29.970 fps
Minimum frame rate               : 19.982 fps
Maximum frame rate               : 59.960 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.204
Stream size                      : 1.19 GiB (98%)
Language                         : English
Encoded date                     : UTC 2009-12-25 13:31:15
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 24mn 32s
Bit rate mode                    : Constant
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Compression mode                 : Lossy
Stream size                      : 22.5 MiB (2%)
Language                         : English
Hope someone can help :slight_smile:
Interesting.  I have a Zi8, too, and don’t have that issue.
One thing I note is the bizarre framerate:   36.69 fps??
Here’s one of mine for comparison:   The frame rate is a correct 29.97 fps.
If the WDTV is unable to handle the VARIABLE frame-rate yours has, then out-of-sync audio is a likely result.
I am unaware of any settings in the Zi8 that allow for a change in constant / variable framerate…
General
Complete name : 560_0207.MOV
Format : MPEG-4
Codec ID : qt
File size : 87.0 MiB
Duration : 56s 957ms
Overall bit rate : 12.8 Mbps
Encoded date : UTC 2010-05-24 17:32:23
Tagged date : UTC 2010-05-24 17:32:23
AMBA :
Video
Format : AVC
Codec ID : avc1
Bit rate : 12.7 Mbps
Maximum bit rate : 15.8 Mbps
Height : 720 pixels
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.459
Stream size : 86.1 MiB (99%)
Title : Ambarella AVC / Ambarella AVC
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 56s 810ms
Bit rate : 128 Kbps
Stream size : 888 KiB (1%)
Title : Ambarella AAC / Ambarella AAC
Language : English
I also have the same issue with files with a constant frame rate of 29.97 fps. Could it be anything to do with the fact that the files are a collection of different files that have been cobbled together?
Quite possible.
One way to tell is if the audio de-sync occurs at the break between two original “chunks.”
How are you concatenating the files?
I used QuickTime Pro. I will have a go with the original files and see if that makes any difference.
The original smaller files work fine, it’s only the edited full length clip that has the audio sync problem. Is this because I edited it in QuickTime Pro? Did I make elementary mistakes while doing so? Should I have used Media Impression instead? Thanks in advance
I have no idea about that, sorry…   Never modified my original files.
