i have an 8GB USB flash drive that can’t hold files bigger than 4GB because is in Fat32 format. So if i change it to NTFS, will the HUB still read the USB drive?
sorry for my english…
Yep
Yes, the WD TV Live Hub can read NTFS formatted drives.
thanks.
Do you know if it damage the USB drive if i format it from Fat32 to NTFS to back to Fat32? Because my stereo system doesn’t read it when it’s in NTFS
Nope, it does not, I have a 8 GB memory stick, I used with my XboX 360 (Fat 32), time to time, I needed to format it to NTFS to move files around, till today, I must have formatted the drive around 29 times and is working like a charm.
