After updating to the latest version of Java, the web interface will just not open.
The Java GUI just hangs half complete, and I get the following error report:
Anybody got any ideas?
Java Plug-in 10.60.2.19
Using JRE version 1.7.0_60-b19 Java HotSpot™ 64-Bit Server VM
User home directory = /Users/MacUser 1
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
createGUI didn’t successfully complete
java.lang.reflect.InvocationTargetException
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1276)
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1251)
at javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java:1347)
at com.wd.nas4g.mapdrive.MapDrive.init(MapDrive.java:125)
at com.sun.deploy.uitoolkit.impl.awt.AWTAppletAdapter.init(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.RuntimeException: java.io.IOException: Cannot run program “mount”: error=1, Operation not permitted
at com.wd.nas4g.mapdrive.command.impl.MacMountStatusCmd.execute(MacMountStatusCmd.java:32)
at com.wd.nas4g.mapdrive.MapDrive.buildSharesUI(MapDrive.java:395)
at com.wd.nas4g.mapdrive.MapDrive.setSecure(MapDrive.java:614)
at com.wd.nas4g.mapdrive.MapDrive.createGUI2(MapDrive.java:465)
at com.wd.nas4g.mapdrive.MapDrive.access$1200(MapDrive.java:65)
at com.wd.nas4g.mapdrive.MapDrive$1.run(MapDrive.java:177)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:302)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:733)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:703)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Caused by: java.io.IOException: Cannot run program “mount”: error=1, Operation not permitted
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1041)
at java.lang.Runtime.exec(Runtime.java:617)
at java.lang.Runtime.exec(Runtime.java:450)
at java.lang.Runtime.exec(Runtime.java:347)
at com.wd.nas4g.mapdrive.command.impl.MacMountStatusCmd.execute(MacMountStatusCmd.java:26)
… 19 more
Caused by: java.io.IOException: error=1, Operation not permitted
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.(UNIXProcess.java:184)
at java.lang.ProcessImpl.start(ProcessImpl.java:130)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1022)
… 23 more
Exception in thread “AWT-EventQueue-2” java.lang.RuntimeException: java.io.IOException: Cannot run program “mount”: error=1, Operation not permitted
at com.wd.nas4g.mapdrive.MapDrive.setNonSecure(MapDrive.java:607)
at com.wd.nas4g.mapdrive.MapDrive.access$2300(MapDrive.java:65)
at com.wd.nas4g.mapdrive.MapDrive$2$1.run(MapDrive.java:275)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:312)
… 18 more
… 22 more
